How can I reverse or change cross hatch line type in a drawing? SW does not automatically reverse or differentiate the different parts, per ANSIY14.5 standard practice.
I suspect that Eddy Alleman has your answer. But you can also change each one manually as needed (even after you have check the box that Eddy shows.
Just select the crosshatch in the drawing viewing area, and then, in the Property Manager, uncheck "Material Crosshatch" and change it as needed.
Hi Ken,
Edit Feature on section view in the feature tree and mark the following:
Eddy
