For example: a door that sits in a frame and when you change the size of the frame, the door changes with it.
Can someone explain how this is done or give me a good article on the web on this subject?
Thank you.
Dennis Hvam wrote:
Hey Daafje,
Normally I use two options when doing Top-down modelling:
1. Create a 3D sketch inside your assembly to control your elements. (Connect your sketch's to the lines of the 3D sketch made in the assembly, extrude sketches to points in the 3D sketch etc.)
See the attached file "Fuld skelet.zip" for that solution its a bit heave, because everyrthing is controlled from a design table. (SolidWorks 2008 sp4.0 version)
2. relate your parts to a "main" frame e.g. the door frame.
See the attached file "Assem110.zip" for that solution. (SolidWorks 2009 sp3.0 version)
There is so much to explain about top-down modeling but I hope that you'll get some info from the exampel files attached.
A good idea is to google "solidworks top down tutorial"
You are always welcome to contact me regarding top-down modeling
Dennis Hvam wrote:
Hi Daafje,
yeah a good idea to start a new post regarding equations.
I had the same problem, but I think that I fixed it with a -(minus) 0.3. that ofcouse only work for this specific part![]()
Anyway I'll check it out and I hope you make a new post regarding it, and if I find anything I'll post the answer there.
