Hello friends,
Through forum help, I had created a macro that will find the part or assembly from PDM Vault and Gets the Latest Version of the file and be opened in the SolidWorks.
It works well for some files but not for all… Please see below for my code…
Dim swModel As ModelDoc2
Dim myVault As EdmVault5
Dim search As IEdmSearch7
Dim result As IEdmSearchResult5
Dim epdmfile As IEdmFile5Dim epdmFolder As IEdmFolder5
Dim DesiredFile As String
Dim ModelName As String
Dim ModelPath As String
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long, longerrors As Long
Set myVault = New EdmVault5
myVault.LoginAuto "PDM-VAULT", 0
Set search = myVault.CreateUtility(EdmUtility.EdmUtil_Search)
search.Clear
DesiredFile = "G2640" ‘------------file name
search.FindFolders = False
search.FindFiles = True
search.FileName = DesiredFile & ".%"
search.Recursive = True
search.SetToken Edmstok_Recursive, True
Set result = search.GetFirstResult
Set epdmfile = Nothing
Set epdmFolder = Nothing
While Not result Is Nothing
Set epdmFolder = myVault.GetObject(EdmObjectType.EdmObject_Folder, result.ParentFolderID)
Set epdmfile = myVault.GetObject(EdmObjectType.EdmObject_File, result.ID)
Set result = search.GetNextResult()
ModelName = epdmfile.Name
Dim eFile As IEdmFile5
If Right(ModelName, 3) = "ASM" Then
Set eFile = result
eFile.GetFileCopy (0)
ModelPath = epdmFolder.LocalPath & "\" & epdmfile.Name
Set swModel = swApp.OpenDoc6(ModelPath, 2, 0, "", longstatus, longwarnings)
ElseIf Right(ModelName, 3) = "PRT" Then
Set eFile = result
Wend
Debug.Print ModelPath
Could someone help me where I am missing…
When you get to the last result you will get null at this line:
But you still trying to process it and only validate the null condition at the beginning of the loop. You will need to move this line all the way down just before the closing Wend keyword
