Construction lines in drawings
Question asked by Alex Lachance on Sep 9, 2020
Latest reply on Sep 9, 2020 by Alex Lachance
Why does sometimes when you use the construction lines command in a drawing. when you click on an edge to do a ''center-line'' between 2 edges, it populates the entire view with lines automatically after the first selection, even though the option is unchecked?
That behavior has existed for as long as I can remember, I remember having it during my classes but the drawings were much simpler then the ones I do now.
It's an annoying one too, it's not even consistent in it's line placement. For instance, the edge I first selected, and meant to select a second one to do a center line, didn't create it's center line, but the other suspension did. You can also see some holes in the beam with construction lines aligned to it, but others without it. Not that it matters because 99% of those construction lines are undesired anyways
