I am curious to know if i is possible to draw a spiral, select an end node and pull it up (or down) to create a helical cone. I know there is a way to create a tapered helix, but I just want to know if there is an alternative. Say, selecting the node and entering a height to spread it along that height while maintaining a nicely spaced coil. Hope that makes sense.
Hi Don
I'm not sure I understand your question - but you can have fun intersecting surface bodies using Tools > Sketch Tools > Intersection Curve or equivalently converting model edges after a trim or up to surface extrude, etc
