Hello everyone, I ask for guidance because I'm going crazy.
I have an article (part) called "DN100 TUBE" with a fixed external circular section of 114.30 mm and a commercial length of 6000 mm (extrusion function).
I have to insert it in different assemblies and even several times within the same assembly, but each instance must have a different length, always variable, NOT STANDARDIZABLE, and above all independent from the part and from all the other instances.
What is the best way to achieve this?
Thanks in advance for your attention.
Hi Giuliano
Infinitely variable lengths are what I have to deal with in woodwork.
In our case we do not have pdm (of which I have zero experience) and the parts live in the project folder and are not shared across projects.
I make a configuration for each use case - ie the configuration is not linked to any particular length but to where it is used.
Here's an example of a deck we did
and a sample of the pick list
As you can see this means that you can have the same lengths in different configurations - which in our case was what I wanted, especially during the design phase. Promoting all the Parts and sorting the BOM by length was sufficient for me.
Here the part number is the configuration name, which was setup to match the sub-assembly structure, which was 2 levels deep.
Understand that we are a small company, who manufacture in-house, so we do not need or understand the requirements of more professional outfits, but maybe this helps.
I mean what else can you do?
I take it you have explored the configuration publisher. I don't use it as I prefer to use Design Tables to create my configurations en masse up front, but I think it is made for your scenario.
2019 SOLIDWORKS Help - Configuration Publisher
The help files aren't the most helpful. From my recollection there are two modes of operation.
One of them allows you to create configs on the fly, the other eases the selection of an existing configuration.
