I just did a save-as on a component of an assembly. The component has the new name and the file properties show the correct, new filename. The problem is that the Feature Manager shows the old name.
What is the trick to get the component names to stay up to date?
Similar to the issue I was having with copy tree today.
Copy tree replaces parts in assembly (like save-as would)?
I ended up having to reboot, and then manually replace the component to fix it.
