I have designed and drawn up a speed handle for a mill vise. This part has a hex shaped pocket that will go over the mill vise hex. Since an endmill will not reach into the sharp corners of the hex shaped pocket, I drew in 1/8" holes to clear away material in those sharp corners.
I have spent hours and hours trying to find a way to get these sharp corners to get recognized in CAM so I can drill them out. The AFR recognizes the hex pocket as an Irregular Pocket, and wants to do a "rough - rough (rest) -finish" strategy, unfortunately leaving all the sharp corner material in place.
I have tried to call up a Spotting Drill to create a CAM operation so I can spot drill the places where I need to drill. But the Spotting Drill only wants to operate on Hole Features, and not the Irregular Pocket. The holes I placed in the hex sharp corners are not recognized as holes at all.
Mill Setup 1 is all I have gotten to work and that is just a stock facing operation.
Mill Setup 2 is where I have been unsuccessfully working on the hex shaped pocket.
I'm sure that I am missing something simple here due to my inexperience with Solidworks CAM.
Hi Terry
I took the liberty of downloading your file and made a video showing how to process this question.
There are many ways to do what you ask, and I show 3 different approaches in the video.
Let me know if the file can be kept online for educational purposes, or if you prefer I take it down after you have seen it.
How to use drills in an Irregular Pocket? - YouTube
Tim
