I want to make an isometric drawing of a cable route and add the curve length to the bends, is this possible in the iso view?
Your best option, or at least one option, would be to create a custom property in the Part, then reference it with a Note in the drawing view.
As soon as I typed this I remembered that you could create the wire as a weldment and then LENGTH would automatically be generated as a cut list property that could be used in the Drawing. If you're going to be doing this fairly often it would be worth setting up, but if not the first option I mentioned above will probably be best.
Thanks Glenn, its only something I have to do to when we order a robot for the cable length and I was sure I could do it in a view by selecting the curve and then the end points but this would not work in an isometric view.
Cheers
Cheers
I just read my reply again, and what it should have said is ". . . would be to create a custom property in the Part that's linked to the Path dimension"
