I don't normally use the rib feature, but I have a set of 4 ribs that are on a vendor part that are perpendicular to a cylindrical surface and connect to a curved weld cap. Solidworks doesn't seem to like it all that well!
Both endpoints are coincident to their respective surfaces and the source sketch is on a plane at the appropriate 45 degree angle. Thoughts?
The way you have it only the center of the rib will intersect the part. If the rib has any width at all, the width will go off into space. You have to either add a little straight line at the right end of the image you show, or lower the sketch at that end so the entire rib intersects material at that end. Common mistake on round parts.
