So I have a part that is a simple pole that is in a sub-assembly that is in a main assembly that has a layout sketch in it. I want to drive the length of that pole from the the main assembly layout sketch. But when I put in the equation in the top level assembly saying the length of the pole is equal to the dimension I put in the driving sketch I get he circular reference error pop up. You guys that do top level layout sketches how do you do something like this?
Instead of using an equation you might try editing the pole Part inside the Assembly and using sketch references to drive the length.
