I want to get entities which is visible to the user from the model. Is there any way for this.
Please let me know your views.
I did not understand what exactly do you need?
I want entities which are clearly visible to the user while using Solidworks.
For example, for the, in front view, I want an only face or 4 edges.
1-CV-413 wrote:
wow.. again.. wth... for some reason.. I'm being blocked by the moderator?
Create a plane parallel to view and make new sketch on it. Select needed faces or/and edges and convert it
Result:
Now you can make planar surface (if you need)
