So, today we have new unexpected behavior. I have an assembly with 20+ internal pipe extrusions. I am adding more in my assembly today and when I go to create new extrusions its now moving fully constrained parts, breaking mates and "fixing it" is not as simple as backing out.
Any thoughts as to what might be happening? 2019 SP5.0, assembly was fully constrained after rebuild. I'm guessing that there's an issue with the inplace mates causing the solver to fail and create errors but I don't why it just started happening today.
I did add some new parts as well. They could have been created in a older versions. I will investigate any lingering old model issues in the meantime.
Well, it's preliminary....but, it may have been an issue where Solidworks just decided to start numbering the new parts the same as the old parts. I went through and renamed all of my internal parts to more specific names and I haven't yet run into the problem again.
I tested it out by trying to create the same extruded pipe that caused the last glitch. No glitch this time. I've got a few more to add this afternoon. Hopefully, this fixed the issue.
I knew it was wise to rename your parts, but I didn't realize SW would break this badly if given the opportunity.
