can you set selection to only the item you selected to make revision? instead of selecting everything?
Question asked by Randy Adams on Aug 25, 2020
Latest reply on Aug 25, 2020 by Jeremiah Feist
When you select a part that you want to make a revision in PDM the window selects everything that it is referencing. Can you make the default to only select that part? If you want to select other items that is referencing it you have to select them your self. I only want to change the assembly and it's drawing. Right now you have to unchecked them by doing a select all then unchecked and recheck the assembly & drawing.
Can you change the default???
