Hallo,
kann jemand mit dieser Fehlermeldung etwas anfangen - und kennt sogar eine Lösung?
Hey,
does anyone know this error message and know any solutions for this problem?
mfg
Janis Bakenecker
Hallo,
Hey,
mfg
Janis Bakenecker
It sounds like Windows does not recognize the application.
When do you get this message (what did you do to try to run the application)?
Is it a Solidworks application?
Did you perform an install of the application on your Windows system.
We need more details to give you answers.
the message pops up, after closing SW2020. At the moment, i get the problem solved by using the Task-Manager to close SW.
But i think, that can't be the right way to get the SW2020 Application closed.
Greets!
It could be one of the add-in's or something else that is linked to the Solidworks session.
Try disabling any features that you can from add-ins, toolbox, or any other optional programs or features.
That might eliminate another add-in or program from causing the problem.
Then you can add the programs or features back in one or a few at a time, to narrow down if one program or feature is the cause.
If it is a add-in you may be able to reinstall that program in the case that the install was corrupted.
can you also translate the error message - I can not read it.
Also, As Glenn Schroeder requested, what is your operating system / version
Hi there,
I had the same problem.
After Updating Office365 from Version 2008 to 2009 it closes without error.
Best regards...
Hi
this thread is also related and has more details:
https://forum.solidworks.com/message/1076164?commentID=1076164#comment-1076164
Eddy
What is your operating system? SW only runs on Windows, so if yours is a Mac that could be the problem.
