Hello, I want to get the surface area of a large assembly, but I want to get only external faces. I saved the assembly as a part, but give me the same result as the assembly. Is there a SW option to save only the external shell ? I need this to calculate how much paint we will need for the assembly. Thank you
from the assembly save-as dialog make sure you selected "exterior faces"
but also remember that the measure tool will give you to total surface area - including the area pointing inside. so divide by 2.
