Macro Rename Draw and change name on feature manager
Question asked by Yerko Gatica Lagos on Aug 19, 2020
Hi everyone, I made some macro for Rename Draw and change the name on feature manager. The maro run very well but a can't change by the same name the part or assemble on feature manager tree.
' Macro 08/19/20 by ygatica
Dim Part As Object
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportData As SldWorks.ExportPdfData
Dim boolstatus As Boolean
Dim filename As String
Dim lErrors As Long
Dim lWarnings As Long
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
Set swCustProp = swModelDocExt.CustomPropertyManager("")
If swModel Is Nothing Then
MsgBox "Sin documento actual", vbCritical
End
If swModel.GetType <> swDocDRAWING Then
MsgBox "Esta Macro solo trabaja en Drawings", vbCritical
End
filename = swModel.GetPathName
filenameOld = filename
If filename = "" Then
MsgBox "Por favor guarde el archivo primero y intentelo nuevamente", vbCritical
End
'save as
FilePath = Left(filename, InStrRev(filename, "\"))
sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
sFileName = Left(sFileName, InStrRev(sFileName, ".") - 1)
'carga formulario on informacion
UserForm1.TextBox1.Value = sFileName
UserForm1.Show
'cambia ventana
Call changview
Call changstatus
'cierra el documento activo
'swApp.CloseDoc filename
Sub changview()
Set Part = swApp.ActiveDoc
Dim COSMOSWORKSObj As Object
Dim CWAddinCallBackObj As Object
Set CWAddinCallBackObj = swApp.GetAddInObject("CosmosWorks.CosmosWorks")
Set COSMOSWORKSObj = CWAddinCallBackObj.COSMOSWORKS
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameLeft = 0
myModelView.FrameTop = 0
myModelView.FrameState = swWindowState_e.swWindowMaximized
swApp.ActivateDoc2 "BE-794 0000.SLDASM", False, longstatus
'StudyManagerObj = Nothing
'ActiveDocObj = Nothing
Set CWAddinCallBackObj = Nothing
Set COSMOSWORKSObj = Nothing
Sub changstatus()
boolstatus = Part.Extension.SelectByID2("Anotacion", "DCABINET", 0, 0, 0, False, 0, Nothing, 0)
Set Feature = Part.SelectionManager.GetSelectedObject6(1, 0)
'Debug.Print Feature.Name
'Feature.Name = "Annotations"
And also ave a form whit this code.
Sub CommandButton1_Click()
'save as
newname = TextBox1.Text
filename = FilePath & newname & ".SLDDRW"
longstatus = swModel.SaveAs3(filename, 0, 0)
'borra oldfile
'Kill filenameOld
Set oFSO = CreateObject("Scripting.FileSystemObject")
If oFSO.FileExists(filenameOld) Then oFSO.DeleteFile filenameOld
'cierra el formulario
Unload UserForm1
Private Sub CommandButton2_Click()
End
