So I currently have a project with multiple pages, and I am trying to make sure my netlist names are consistent. I have a netlist that is connecting a processor pin, with a d-sub connector pin, and along the path there is a node that leads to a resistor and zener diode to ground.
So the processor pin and the d-Sub both have a name for the net, FLOW, but the net from the resistor to the diode to ground keeps getting renamed as NETDXX using the programs autonaming feature. I can manually rename the net, and use the configure physical nets feature of the netlist manager, but everytime I try and import other changes, the program wants to rename that net back to an autonamed feature. Any ideas on best way to handle this?
Thanks!
Can you provide a screenshot of the schematic as well, showing the two components that you are connecting?
BR
Markus
