When using pin connectors in SolidWorks Simulation 2019, the connector force results table shows Joint 1 & Joint 2 forces for the Pin Connector-1. Should I compare Joint 1 & Joint 2 and use the maximum force values, add them together, or is there a way to show only one set of force values for each pin connector? I have selected two concentric holes to define the pin connector.
