Hi all,
I made my first macro and it seems to work just fine. However I have one problem that i can not solve.
The macro creates a new drawing from a part/assembly based on a drawing template. I added some msgbox in case the file already exists. This al works fine. But when trying to save the newly created or existing file with the save button (or ctrl-s), after running te macro, the 'browse-for-file-dialog' pops up instead of just saving the file.
It looks like the 'session' is not aware of the 'save-action' in my macro. So it reacts like the file was not saved before. If you know what I mean...
Dim swApp As Object
Dim Model As SldWorks.ModelDoc2
Dim Part As Object
Dim Part2 As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
'Bepalen van path en bestandnamen
Dim MyPathName As String
Dim MyPath As String
Dim MyFolder As String
Dim MyFile As String
Dim MyPrePath As String
Dim MyTemplatePath As String
Dim MyDrawingPath As String
MyPathName = Part.GetPathName
MyPath = Left(Part.GetPathName, InStrRev(Part.GetPathName, "\") - 1)
MyPrePath = Left(Part.GetPathName, InStrRev(Part.GetPathName, "\Google Drive\") - 1)
MyFolder = Right(MyPath, Len(MyPath) - InStrRev(MyPath, "\"))
MyFile = Right(Part.GetPathName, Len(Part.GetPathName) - InStrRev(Part.GetPathName, "\"))
MyTemplatePath = MyPrePath & "\Flemac bvba\SW Design Team - SW Library\SW Drawing Templates\Flemac - A3 Portrait.drwdot"
MyDrawingPath = Left(Part.GetPathName, Len(Part.GetPathName) - 6) & "SLDDRW"
Debug.Print "----------------------------------------------------" & vbCrLf
Debug.Print " My Path & name = '" & MyPathName & "'"
Debug.Print " My Template path ='" & MyTemplatePath & "'"
Debug.Print " My path = '" & MyPath & "'"
Debug.Print " My folder = '" & MyFolder & "'"
Debug.Print " My file = '" & MyFile & "'"
Debug.Print " Drawing path = '" & MyDrawingPath & "'" & vbCrLf
Set fso = CreateObject("Scripting.FileSystemObject")
If fso.FileExists(MyDrawingPath) Then
If MsgBox("Drawing already exhists. Do you want to open the exhisting file?", vbYesNo, "Exhisting Drawing") = vbYes Then
'Open exhisting document
Set Part2 = swApp.OpenDoc(MyDrawingPath, swDocDRAWING)
Else
' Create New Document
Dim swSheetWidth As Double
swSheetWidth = 0.297
Dim swSheetHeight As Double
swSheetHeight = 0.42
Dim swDrawing As DrawingDoc
Set swDrawing = swApp.NewDocument(MyTemplatePath, 12, swSheetWidth, swSheetHeight)
Dim swSheet As sheet
Set swSheet = swDrawing.GetCurrentSheet()
swSheet.SetProperties2 12, 13, 1, 20, False, swSheetWidth, swSheetHeight, True
swSheet.SetTemplateName (MyTemplatePath)
swSheet.ReloadTemplate True
swDrawing.InsertModelInPredefinedView (MyPathName)
Dim myModelView As Object
Set myModelView = swDrawing.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
If MsgBox("Would you like to overwrite the exhisting file?", vbYesNo, "Overwrite") = vbYes Then
' Save As
longstatus = swDrawing.SaveAs3(MyDrawingPath, 0, 2)
This is my first post here. So please forgive me if I do something stupid ;-). I obviously took some codes from examples I I found on the internet.
Hope someone here can help me with this.
I run the code and it works as expected- if I chose to open an existing drawing or create a new drawing and chose to overwrite the existing subsequent save command saves the drawing without further questioning.
However- if I chose not to overwrite the existing drawing then naturally File Save As... dialog box pops up at save command as the new drawing still does not have a name...
I like how the macro is written. Just few side notes:
The macro does not handle the situation where there is no drawing for the part
It will fail if run on a new part (not saved yet)
As Artem suggested set the parameter to 1 although in this case I wonder- save as copy might be doing the same thing.
Thanks a lot for your reactions. Changing '0' to '1' did not solve the problem unfortunately. Maybe I should "re-open" the drawing or something like that. But that seems a bit strange to do...
However I come across a new problem and I can not figure out what is wrong. When I run the macro on my "test assembly" it works as it should.
When I try to use it on a different part/assembly it does nothing. I think the following line is causing the problem.
I copied it but have actually no idea how it works...
You should change 2 to 1 (last parameter), not 0 to 1
