Hi All,
I'm reading this FEA study and it states the following used to prepare the model:
- The components are constrained as depicted in image 1.
- The component is attached to an actuator at the arm and is
braced by supports with bearings at the pivot that give a hinge
like mechanism. - The mast is attached via the plate using bolted connectors,
which are not modelled. - The actuator and pivot are assumed within the model as a
rigidly pinned support (all three directions constrained) with
rotations allowed. - Kinematic (RBE2) couplings are used to transfer the boundary
conditions to the surfaces. - The moment load is acting about the z-direction and is
distributed on the plate with a diameter of 100mm, again using
a kinematic coupling. - The moment is calculated at 425.46Nm.
So I'm wondering how I should prepare the model by applying forces where and what fixture to use and any boundary conditions. I've attached a file, if someone could prepare it for me to show me how it looks from running simulation will be very helpful.
I've also attached image 2 to show simulation results from this preparation.
Edit:
The Assembly file contains the mast 14kg, camera kg and head with lights 17kg. It's shown how its connected.
Babar.
Is this for your homework project? (edit: n/m I see that you asked this question 3 months ago.)
1. The 'constraints' shown are unrealistic and invalid in the real world. (Bearings do not have a suction effect.)
2. How can you have something 'rigidly fixed' yet allow rotation?
3. Why would you have a kinematic coupling on the plate? Are the bolts acting as stand-offs? Again, totally unrealistic.
4. Why do you have your stress scale going to 417 MPa while it appears as if your max stress is 215 MPa? You seem to be truncating information which would be useful.
5. How could anyone run your simulation for you if you don't supply the loading forces, i.e. the cylinder that is rotated, mass, CG, etc.?
