SW corp marketing implies that a mere slip of a youth can
analyse the suspension of an open wheeler racing car; but my
reading of CM text User Guide (2001), Step by Step Guide (2008),
hypertext Reference (Help) Guide (2009), Tutorial (2009) and Motion
training syllabus has found no example of anything more complex
than a 2D planar mechanism.
So I have jumped in at the deep end with a 3D mechanism and I am attempting a process of elimination by asking one question at a time.
Can ADAMS solve the 3D mechanism in the screenshot below?
I no longer work for MSC/MDI, but I can assure you that this is the main use of ADAMS in every auto company worldwide. Admittedly there are special modules that help automatically build the underlying models based on company best practices, but the underlying solver engine in Motion is the same.
As far as modeling these types of systems, the main challenge in 2008/2009 relates to determining the appropriate SW mate to get the mechanical joint. I have not played with the universal joint added in 2009 much, but that should help in defining a nonredundant kinematic system. This is the classic joint used in ADAMS/Car for eliminating redundancies.
When you are more interested in a more dynamic model, bushings are the way to go to add compliance to the system. I have not pushed the solidworks joint bushing representation to it's limit to see how well this addresses the needs. I would love to just have a bushing entity that I can define manually for this purpose.
If your bodies in the image are mounted with 3 ball joints, then there are redundancies (bogie has 6 dof and each ball joint tried to remove 3 for a total of 9) so either bushings are going to be needed or one of the ball joitns needs to be adjusted.
It's a little unclear to me still on the full setup of the model. For example, are the bogies free to translate/rotate with respect to ground in all directions? Do they stay parallel? etc. Are there shocks in the system to limit/dampen travel?
The first step I find is locking the engine in space and articulating the linkage system to ensure it is working as expected. Once that is confirmed, then enhance the model to provide ground inputs to the system and observe the response of the vehicle.
Cheers,
Ian
