I'm looking to make a macro that generates parts and saves them to a new folder. I've figured out how to define the part and folder names based on user input, but I cannot find a way to create a new folder in Solidworks API. Is there a command that can do this? Looking online I found this link How to: Create a Directory - Visual Basic | Microsoft Docs, which has this code below for creating folders. I cannot find an in context example showing other details needed to use this code.
My.Computer.FileSystem.CreateDirectory( "C:\Documents and Settings\All Users\Documents\NewDirectory")
The file below was my attempt at using this command but i get a an error "Run-time error '424': object required"
Also, This seems like it should be a really basic thing to do with code but I couldn't find a good resource for this. Is there a good place to go to fine basic information like this?
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
'initialive program
Set Part = swApp.ActiveDoc
'define part and folder names
Dim FolderName As String
FolderName = "Job Folder"
Dim FileName As String
FileName = "job file"
'Create string variables for saving
Dim Savetofolder As String
Dim Saveto As String
Savetofolder = "C:\Users\shawnk\Desktop\" & FolderName
Saveto = "C:\Users\shawnk\Desktop\" & FolderName & "\" & FileName & ".SLDPRT"
'Create New Folder
My.Computer.FileSystem.createdirectory ("Savetofolder")
'Save part
longstatus = Part.SaveAs3("Saveto", 0, 0)
Part.ClearSelection2 True
Thank you for reading!
