Hi all,
I am trying to change the sheet metal Gauge table parameters using the API:
However the option to set the Gauge table name is not available on the ISheetMetalFeatureData.
The only way I have found is to go through the IBaseFlangeFeatureData and set the ThicknessTableName property.
And I have already visited the two links below:
So is there a way to set the gauge table name in the case when the assembly does not contain any Base Flange feature? (for example a converted part)
And same question for the Radius property in this same scenario?
Thank you!
Rasmus
