AAAndrew Alderfer10/08/2020
I am having an issue with a stamped tool where it gives me the error: "The part's thickness may not be compatible with this form tool. The thickness must be less than the minimum radius of curvature for the form tool." whenever I try to use it on 0.049" material. I have used very similar stamped tools and they have worked fine but this one is giving me issues. I am open to editing dimensions by a couple of thousands because it is a stamped part and does not need to be perfect. If you have any recommendations or can point me in the direction where my problems are then that would be greatly appreciated.
