In the Appearance tab in the Edit Material dialog box, I have everything grayed out for selecting default appearance for a material - see attached. What's the trick to enable this?
Best regards,
Anand.
Best regards,
Anand.
You need to copy the material to your custom library to modify it.
First create a new library, don't use "Custom Materials"
Then copy what you want to change to the new library.
