Hi All,
Is it possible to select all identical imported part bodies in an assembly? We have roller conveyor systems which are build up from imported parts, so all frame work and rollers are imported features.
I was looking for a simple method to hide all rollers in the assembly for lighter DXF export, but since the complete conveyors are parts, they will be completely selected when i choose 'select identical components'.
I have also tried to select it form the 'Solid Bodies' folder with no luck.
Anybody have any ideas??
Thank in advance and stay save.
Willem,
If it's an Assembly, would the Assembly Visualisation tool on the evaluate tab be any use to you? You could select items by quantity or mass & either hide them directly by right clicking or return to the FeatureManager Design Tree to see your selection & hide, isolate or delete from there.
This option isn't available as far as I can see if your model is a multi body part.
