I try to run a simple static simulation. I usually have to re-mesh. Then sometimes it works, most times I get the message below. Today, I did a force study on a pipe and it ran fine, the I did an FOS study and got results. I then added 0.007” to the wall thickness and re-ran and it doesn’t complete. I usually get the message below.
I've saved completed studies and when I open the file and re run if fails. What might I try?
This is Problem with the data format in the results.
Delete the results and run the study again.
