Hello I found a macro in Solidworks API Help, it works great, but i really need to modify it a bit.
1. I would like the macro ask for the part file's location instead of specifying it in the macro.
2. I would like instead to see a browse folder window with ability to make a new folder, for the location of the pack and go results, instead of specifying it in the macro
The option to add a prefix to all of the filenames would be handy as well.
Thanks!
' Preconditions:
' 1. Verify that the specified part and equation documents
' exist.
' 2. Verify that c:\temp exists.
' 3. Open the Immediate window.
' Postconditions:
' 1. Opens the specified part document.
' 2. Adds the part and linked equation documents
' to Pack and Go and copies the files to
' c:\temp.
' 3. To verify, examine c:\temp.
' NOTE: Because the model is used elsewhere,
' do not save changes.
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swEqnMgr As SldWorks.EquationMgr
Dim swPackAndGo As SldWorks.PackAndGo
Dim fileName As String
Dim errors As Long
Dim warnings As Long
Dim i As Long
Dim nCount As Long
Dim eqnLinked As Boolean
Dim pgFileNames As Variant
Dim status As Boolean
Dim statuses As Variant
Dim myPath As String
fileName = "C:\Users\kevin\Desktop\resizeable chassis\1.sldprt"
Set swModel = swApp.OpenDoc6(fileName, swDocPART, swOpenDocOptions_Silent, "", errors, warnings)
Set swModelDocExt = swModel.Extension
Debug.Print "File = " & swModel.GetPathName
Debug.Print " "
' Get Equation manager object
Set swEqnMgr = swModel.GetEquationMgr
' List the equations, get whether they're linked
' to files, make sure any equations are up to date,
' and get the paths where they're stored
nCount = swEqnMgr.GetCount
For i = 0 To nCount - 1
Debug.Print " Equation #" & i & " = " & swEqnMgr.Equation(i)
eqnLinked = swEqnMgr.LinkToFile
Debug.Print " Equation linked to file? " & eqnLinked
If eqnLinked Then
'Make sure equations are up to date
swEqnMgr.UpdateValuesFromExternalEquationFile
'Get path and name of linked equation file
Debug.Print " Path and file name of linked equation: " & swEqnMgr.FilePath
Next i
Debug.Print " "
' Get Pack and Go object
Debug.Print " Pack and Go"
Set swPackAndGo = swModelDocExt.GetPackAndGo
' Get current paths and names of the documents
status = swPackAndGo.GetDocumentNames(pgFileNames)
Debug.Print " Add these SOLIDWORKS files to Pack and Go: "
If (Not (IsEmpty(pgFileNames))) Then
For i = 0 To UBound(pgFileNames)
Debug.Print " The file to pack up is: " & pgFileNames(i)
Next i
' Set document paths and names for Pack and Go
status = swPackAndGo.SetDocumentSaveToNames(pgFileNames)
' Override path where to save documents
myPath = "c:\temp\"
status = swPackAndGo.SetSaveToName(True, myPath)
' Pack and Go both SOLIDWORKS and non-SOLIDWORKS files
statuses = swModelDocExt.SavePackAndGo(swPackAndGo)
