I am trying to design a
linear cam
Right now the path of the follower is defined and constrained by assembly mates. I can drag the follower and watch it move along the desired path. The video shows the follower going through the material of the cam body as I drag the follower left and right.
I would like to cut the excess material from the cam body in such a way that if the follower is tangentially mated to the cam profile, it would follow the same exact path without the existing assembly mates that make it do so in the video.
You need to upload your file for someone to fix the assembly/parts for you.
Look here on How to Attach File Make sure you include assembly and all related parts and do zip your file before uploading. Also mention which version of SolidWorks you working on.
