I basically have a tube with slots cut in a pattern down the length, and I need to coil it in a spiral. However, when I use the flex command to take the straight tube and coil it, I get a weird render issue where the solid looks inverted somehow. Not sure why this is; any fixes or other methods to achieve this same part?
It can be done by a different method but it is a tedious work. I have shown only a group of slots. You can have other slots in a similar way.
