Hello!
First post so I apologize for any rookie mistakes.
I am going insane trying to solve this issue. The part is giving me the intersect error and I can't find any issues with the part.
I have tried/checked the following:
- Reduce flange and base flange size my a small amount (.1mm) and large amount
- uncheck the corner treatment box on the flat pattern
- close, open, rebuild countless times
Any suggestions are appreciated because I'm all out of ideas.
Check Trim side bends:
Also, for future, I suggest the base flange be the larger portion of this part.
Among other things, this would allow you to select both edges in one flange op.
Kevin
