I am pretty sure that it related to appearance. Somehow I accidentally click on remove all appearance and since that the display style is not functioning. I tried google and all and I couldn't found the answer to my problem. I hope I can find the answer in this discussion.
Herewith I attached my model in SW and Parasolid for easy access.
The picture below when I clicked the hidden lines visible and nothing happen
Hi Jim,
I couldn't find solid bodies. Can you help me?
Hi Jim,
I found it. My problem solved. Thank you for the help!
Nur Athirah
If your issue is solved please mark Jim Sculley's reply as the correct answer. That way people can see there is a solution to your question.
John, issue is solved Nur Athirah forgot about this forum. Until another problem, but he say "thank you" at least
