Please tell me.
I want to measure the shortest distance between parts with VBA, like the attached capture.
I am using SOLIDWORKS MBD 2019 to output 3D-PDF.
The API I'm using is VBA.
I was able to output 3D-PDF, but I do not understand the API for 3D-PDF security settings.
When outputting from the UI, you can set "Disable 3D PDF editing", "Set password", etc. in the security settings.
I would like to know the setting method when outputting with API.
Please let me know if there is an API for setting.
Thank you.
