Hi there, I'm trying to automatize the order of the components in my BOM.
I'm using several additional columns (then hidden) in order to follow my rules
Article Number
Designed components ("Make"):
301
302
303
30x
Commercial componenents ("Buy")
101
102
10x
An initial separation is driven by a custom property called "IsCommercialComponent" (which can be "0" o "1") (setted in every single part/assembly of a commercial part/component)
In this way at the bottom of my BOM I have all the commercial components, separated from the "designed components".
I've managed to get a full list order till this stage
initial stage (with all the list starting from 301...)
301
302
303
320
321
30x
to
301
302
303
122
123
12x
And it's quite fine...
To manage to have a the:
122
123
12x
"resetted" to
101
102
10x
I need a "minimum" function which looks for a minimum value of a column.
Or at least the minimum value among a selection of vertical cells (of a column) (example K2:K33), like in Excel (well, in Excel this operation is much easier).
I've found this:
2019 SOLIDWORKS Help - Equations in Tables and BOMs
But I can't use the MIN() fuction... it seems to not recognize nor the a group of cells nor an entire column.
Is there any step I missed?
Is there any way to enable this function?
Or any other way to get into a result?
