I am trying to model bent metal. I can use fillet on one portion but not the other 3. It flips the fillet in the wrong direction. I've tried fully defining the sketch and flipping where the extrude sketch is drawn to problem solve. I'm stuck.
It's all thanks to beginners luck up until now. I forgot there was a sheet metal option to pick. I don't know how to merge bodies. Thanks for the tips.
I simply merged the result in Extrude5 and the fillet worked after that. Thanks for the help. Just a noob. I attached a screenshot of where the option is in extrude to merge result and uploaded the fixed file.
Your model has 4 different solid bodies and they are all not joined.Try to join using combine feature or select merge option in Extrude5
If you are trying to make a sheet metal part, why not use the sheet metal features from the start?
