Watched an nice instruction on creating a Spring, this example is one method, however I want to have 1 1/2 - 2 turns at the TOP & BOTTOM, know that I need to edit the design to add those feature with the 'VARIABLE' comand, however I cannot find it within the 'SWEEP' command as the Utube instructions explain, therefore I'm asking for some assistance to find out how to get to the 'VARIABLE' comand.
As Krzystof mentioned, you will need to add the variable under equation
2019 SOLIDWORKS Help - Equations
Alternative:
You might want to look at the macro below that is used to create spring
API: Create Spring Macro Feature (VBA)
