Being a learning Sr. person, and self taught student of Solidworks I am wanting to mesh the miter gears in this assembly so that I can see the cam rotate and operate the rods that control the valves. (The Assembly is titled 'Assem Complete Engine').
Secondly I will want to design a Spring that operates the 'Exhaust Valve' at the bottom of this assembly, that will load the actuator against the Cam that is on the same shaft as the Miter Gears.
Would appreciate some guidance here.
Have you tried a gear mate?
