Trying to create a pdf (Tried a save as pdf) but the view flips or rotates on the pdf?
Tried to make a pdf as a (print as pdf) and get extra features on the pdf?
Any help to this problem would be appreciated.
Thank you,
Todd
Thank you,
Todd
It looks like this SPR:
SPR #: 639640
Product: SolidWorks
Status: Implemented
Fixed in: 2021 b2
Area: Drawings
Sub-Area: Translator - PDF Out
Customer Impact: Medium
Enhancement
Summary: Translator - PDF Out: Flipped Sketch Picture was moved when drawing convert to PDF.
Interestingly, if you flip the sketch picture of the left view, the export is OK. But if you then flip the picture on the right, the problem returns. I duplicated your issue using my own files, so it is an inherent problem in SOLIWORKS itself. I tested with SW2020 SP3 and SW2017 SP5 with the same results.
That is odd. You will also need to upload the referenced model(s). We can only open the slddrw in quick view mode and only option for save as in tiff.
