Hi guys, i'm wondering if this macro could be adjusted to so the macro saves the PDF to a specific location (defined in code) rather than the location of the source file?
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtention As String
Dim NewFilePath As String
FilePath = Part.GetPathName
PathSize = Strings.Len(FilePath)
PathNoExtention = Strings.Left(FilePath, PathSize - 6)
NewFilePath = PathNoExtention & "pdf"
Part.SaveAs2 NewFilePath, 0, True, False
MsgBox "Saved " & NewFilePath
Any direction would be greatly appreciated!
RG
Try replace your code
with the following code (You need to change the folder path in red)
I had not tried it out, but it should work.
