BTBrent Theobald15/07/2020
Howdy Gang,
This is a SW 2019 question.
I have a pin I need to copy with mates. The pin is fully defined - mated. Now I want to populate the connector with the rest of these pins.
SW says:
"Mates to be copied with selected components are under defined"
However, if I try to pick the pin and drag it around (you know, to see where it is loose) I get this:
"The selected component is fully defined. It cannot be moved."
What's going on?
ß!
