Has happened now on several complex drawings, where the drawing looks fine, the preview looks fine, but when sent to the printer, one or more views are only partially reproduced, and the other portions of those views is mis-positioned and mis-scaled else-where on the print. Sometimes can resolve the problem by simplifying the drawing, transferring views to a second sheet, and printing only one sheet at a time. Today I cant seem to get the output required.
Sometime its the printer.
Old printer has less memory and will go crazy trying to print complex drawings.
See which printer driver you're using: PostScript or PCL.
Try different version, even older one.
