I'm trying to release a drawing. Our PDM has rules in place for various data card entries and won't let it push to the next level without all the fields filled in (a safe documentation feature I suppose). The problem I'm having is that I fill the fields in when I have the Drawing checked out. Then when I hit save and check the properties again, the fields are empty. Again, I can't push this DRW file along without those field populated. Is there some other feature that could be depopulating it when I hit save? Even if I try to skip hitting rebuild or save and just direct checkin and release, it still de-populates the properties fields? I'm attaching pics for clarity hopefully.
Hitting this button, bring up these fields...
This is the error I get when I try to checkin...
Any help is appreciated.
Hi Chris,
Can you try closing the file and while it is checked out, edit the data card fields from file explorer? After editing, hit save on the data card, click off the file and back onto it. Does your added values retain at that point? If yes, check it in and check the card again.
Also make sure to check if there are differences between the @ and sheet tabs on the datacard as well.
