I have created Document records in SOLIDWORKS Manage 2020. The Document Records contains several Fields. The value of the fields given in Record properties must be linked to the custom property of the document related to the record so that the value of fields in record properties can be automatically filled in the table cells of the related documents. Kindly provide me information regarding the same.
I have done this in PDM Professional, but not with the Manage add-on. Do your document record fields show up on your datacard?
If they are datacard values you can set it up like this.
In the variable create an attribute that is a CustomProperty and assign it to the desired file extensions.
Add the variable to the datacard.
Then, in Word create the corrisponding Custom Property.
Then, on the document itself, create the field that links to the custom property by entering some text --> Selecting it and right clicking. Select DocProperty from the left column and the desired property from the right column.
Hope that is helpful.
