Hi, I am trying to wrap "scribe" a sketch onto a cylinder surface but I am getting an error. Any help/advice is appreciate.
Maha Nadarasa wrote:
Also is possible that plane with sketch for wrap intersect cylinder
Sketch self-intersect or as wrote Zhen Wei Tee have open contour(s). Or maybe is too long?
You sketch seem to be "open" (based on the software interpretation) so wrap feature could be created
You may
1. Option 1: Clean up the sketch
Redraw the line at the most bottom left as the left point/vertex seem to not connect to the bottom point/vertex of the left line
** You might want to remove the construction line to ensure you connect/snap to the correct point
2. Option 2: Use a separate sketch (Quick and dirty) but not recommended
Create a new sketch and use convert entity on the original sketch (this will create a closed sketch), then wrap
