There are may ways to create a laser cut program. But, for solidworks cam, what is the best strategy to create toolpaths for laser cutting? I attended CSWP CAM once and I failed because of the laser cut question.
Everything was ok, I defined the pockets then created opp plan and selected the endmill tool that they told me to select and then then generate toolpath. But still wrong?
Do I need to combine the operations or something else I'm missing?
Can someone help?
I would assume you need to look at the toolpath itself. When you do fab cutting, you need to have only one pass around the profile. By default, you will get multiple passes. You will need to change the depth parameters and step over on the contour pass.
Mike
