My Flow "ribbon" menu has disappeared after 2018SWX crashed and I can not restore it. I toggle the "Add Ins" and the ribbon does not come back. I can run Flow just fine using the pull-down menus but I need to figure out if there's a way to restore the ribbon menu without reloading 2018.
And yes, I have right-moused on the ribbon tabs and Flow no longer appears in them as it used to.
Any ideas? This is the ribbon I'm talking about (this is 2019)
Right click command manager area -> Customize -> Right click on any tab -> Add Tab -> Flow Simulation Main
Above method will add most of the general used tabs in flow, rest you can drag and drop after searching them from command search in upper right corner or using command tab as shown in image.
Sumit
