I would like to duplicate some simple geometry in a sketch
using the copy from a base point and repeat it to another base
point. The repeat button does not work - it is not selectable!
The
Repeat button only becomes available for the
X/Y distance option. Which makes sense. If you use the point
to point option, then another point would need to be specified for
each repeat.
If you just want to repeat a 'copy' along the same direction and
distance, then use the Linear Pattern tool.
If you just want to repeat a 'copy' along the same direction and distance, then use the Linear Pattern tool.
