Can someone help with this extruded question? I created a part using the extruded boss, then I changed the sketch and it looks correct when in the edit part of extruded boss but when I select finish check mark it reverts to the old sketch not reflecting the changes I made to the sketch.
John, there should be a few reasons. I can't open your zip cause I have an older version of SW. But when you change in the sketch, on the top right-hand corner are you exiting from the sketch. If you exiting from the sketch then it should take it right away.
The second I believe extrude feature manager selection, which you have to correct selection "from" and "direction 1". I hope I could open the zip. But these are the reason it could be.
