I just installed SW2020 and stated playing with it
"Use Software OpenGL" options is grayed out while it's available in older releases
Am I missing something here or any change I'm not aware of?
..as you know, most systems nowadays have two graphics options, the integrated cpu/gpu from intel and a independent nvidia gpu and the SW install somehow grabs the intel gpu?
It could be your system was idle (low power) and using only the intel gpu (the nvidia was dormant, secondary?) while installing?
If it's not already set in the nvidia control panel for Solidworks.. suggest setting the nvidia default at High-Performance (primary) so, the intel gpu is secondary.
